Hey im sorry im sure this has been covered multiple times but im getting confused searching the forums.
Basically i just purhcased a dvdrw which is on its way, and i need to figure out how to burn/author new types of files i havent come across before with cds.
First is vob, i believe on nero i click UDF (not UDF/ISO? whats the difference) and put them in a folder called VIDEO_TS, and nero will do its magic.
Second if i have an image, like an ISO, NRG would i use the UDF/ISO mode and burn the image like you do with cd's?
Any other help would be great, i was thinking of download kill bill 2 until the dvd is officialy released as i loved it in the cinema,
With these zipped rar files, i presume i would need to unpack before i can burn them, and i therefore presume it would take up 2 dvd's due to the size?
link removed
Thanks for all your help, im sure after a few attempts ill be fine
Andrew
You are in breach of the forum rules and are being issued with a formal warning. Do NOT link to warez. Don't do warez.
/ Moderator Baldrick
Closed Thread
Results 1 to 1 of 1
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 10:11 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
