This may be a little late, but I've had the same problem while trying to convert some avi's. I could figure out how to do it, but I eventually got it. When you get your template loaded, click settings. Under the video tab, the bitrate part also has a settings button. Do this on both. Click it and hit ok. These areas are blocked out where you can't change them, so you do not change anything. Tmpeg for some strange reason will then let you encode. Weird as hell, but it works. I put all of my seinfelds on standard vcd's using it!! Hopefully someone else with this problem will be helped, because this is a few months to late.
Results 1 to 1 of 1
Finding out the peak bitrate of a DivX file
By Anakin in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 16:25 -
Mpg : Mpeg video size and bitrate calculation
By Bonie81 in forum ProgrammingReplies: 2Last Post: 21st Jun 2011, 23:38 -
How to test MPG files for errors?
By madmartian in forum Software PlayingReplies: 1Last Post: 17th Jun 2009, 15:30 -
AVI to MPG: Optimum bitrate?
By NDMMackay in forum Video ConversionReplies: 10Last Post: 12th Oct 2008, 11:03 -
Divx 6.8: bitrate vs target quantizer?
By peggypwr1 in forum Video ConversionReplies: 1Last Post: 5th Feb 2008, 22:35
