Ok, so i'm using it with CCE SP 2.50, but I am getting some message everytime, with every DVD I try...
"There is nothing to do. You must encode and prepare before you can rebuild"
Anyone the reason for this?
I used AfterDawn's guide, but I get this problem...
Something I need to do to fix it?
Maybe this,
Quoting Deuteros in the DVDRebuilder forum ...
'... I had problems getting this to run with CCE to start and then found ECLCCE and a guide that indicated that you put THAT as the CCE encoder and not CCESP.exe. As soon as that little thing was sorted it worked fine....'
Also check your EclCCE.ini file has the correct path to CCE - mine looks like this:>
[EclCCE]
CCE=C:\Program Files\DVD-Rebuilder\Tools\Cinemacraft\CCE250\cctsp.exe -
make sure CCE is set correctly in DVD REBUILDER. take a look at the DVD REBUILDER forum at dooms9.org. there is a FAQ section and SETTINGS section.
bd-rebuilder problem
By mathbes in forum Blu-ray RippingReplies: 3Last Post: 12th Feb 2012, 04:15 -
BD Rebuilder new version problem
By fazza8 in forum Blu-ray RippingReplies: 5Last Post: 20th Aug 2009, 06:36 -
BD Rebuilder 22.01 Problem
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 2nd Jun 2009, 13:36 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
