im currently using Sonic Mydvd to make dvds. the flat still picture i used as background gets cut out like one or two inches from the edges. Does anyone have suggestions for great software that is easy to use and have good features on the creative side.
it is the same problems as with your subtitles, it is called overscan. do a search for that on this site and you will get lots of information.
my main question is, what are some great software that is kinda easy to use and has alot of good features on custom menu/ bg building. I especially dont like the buttons on software i use. The stock ones look horrible.
If you don't like them, then the best thing to do is to create the buttons/menus in another program like Zweistein and use DVD-Lab or if you are familiar with AVISynth, use DVDAuthorGUI which will generate a basic menu for you.
Have fun stormin' the castle!
RogThere are many ways to measure success. You just have to find your own yardstick. -
Ulead DVD Workshop 2.011 (full edition AC3)
does anyone know if there is any that has drag-n-drop buttons, so i can actually choose where i can place things.
Extracting menu buttons
By headless chicken in forum MacReplies: 0Last Post: 2nd Apr 2012, 23:54 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
All-in-one program for multiple avis to dvd with menu and good quality?
By Yaeli in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2008, 15:01 -
Menu with image buttons
By lex1972 in forum Authoring (DVD)Replies: 5Last Post: 24th Nov 2007, 07:02 -
Menu Buttons looking odd
By TerryNG in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 00:28
