I have a 700MB+ avi file, and i need to split it into two smaller avis.. Virtual Dub is suggested, but everytime i use it to split the file into two, the audio is out of sync with video.. i have yet to hear a correct way to fix this problem.. i would be greatly thankful if someone were to help me out..
Results 1 to 13 of 13
i have excatly the same problem, but only with avi´s in 23.976 framerate. no problems with avi´s in 25,00 framerate.
i would also be greatly thankful if someone can help. -
there are a few nice little progs that will resync the audio for you that u may still be able to download from digital-digest.com, the one i tested is avisync, it works on dvix files aswell & it takes just a few seconds. The prog changes the frame rate slightly and will resync the audio & video 2gether again.
i guess AC-Sync would work if i had a PCM Codec or whatever it is, is there any other method i can sync the audio and video or is there any way i can get a PCM Codec?
When splitting files with VirtualDub make sure both Audio and Video are set to "Direct stream copy". That will fix the getting out of sync problem.
Cheers,
Mike
I already tried that method.. audio and video are still out of sync.. there must be a way to correct this..
I have the exact same problem but with mpeg 1 (VCD 2.0 1150kbs/s) I tried VCDCutter & TMPEG, and the second half is always out of sync.
PLEASE HELP !!!
well blow me over someone has mentioned vcd cutter... this program cause all my out of sync probs in the first place & it screws the film once it is burned sometimes not even working when finished!! Tmpeg is a common fault with Mpeg splitting especially if U have ripped & american dvd & then returned to doing a UK one.. audio goes miles out.. first disk will be fine but the second one well out. the hard way is killing your system & reinstalling everything or simply look for the registery entries for tmpeg & deleting them. Simply put the new copy back on. The other is really easy, just put tmpeg on another drive & it should work!
Kev! -
I have the same problem but on single file movies. Audio is good at beginning and end but drifts off in between and is quite bad at the middle. Please help.....
well i dont know how to fix avi problems but i can tell u how to fix mpg probs..just extract the sound (either with vdub or in tmpgenc) then use tmpgencs multiplex tools (takes video and audio from different sources) this fixes all sync probs ;o)
hope this helps -
When I get audio out-of-sync problem, I usually de-multiplex my mpeg files with Tmegenc, which split the mpeg into two separate video & audio files. I would then use BBmpeg to put them back together. depending on how bad the out-of-sync is, I would either delay the audio or video file for 500 ms to 800 ms ( more if it is really bad). The result I get was pretty good. Hope this helps
For mpg files, try TMPGenc Audio Gap Correct.
Setting-> Advanced-> Source Range (double-click), Audio Gap Correct. Positive values move sound earlier, negative values delay the sound.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
