I was capturing a 54 min show using divx4 codec and virtual dub, my system is a 500MHz celeron with 64megsram and I 40 Gig hard the has 38gigs empty. It was capturing at NTSC resolution and was going fine but all of a sudden I saw that the hard drive was really really busy and the video stopped for a couple of seconds, I assumed that it was because it ran out of space in the area that it was writing to and was trying to find more room, but since I dont have enough memory to hold all of that unsaved video it just dropped all of those frames,because after the drive calmed down the capture was fine,it was when I played it back that I saw the problem at the point where it froze the video stops for about 5 seconds and then starts up fine again only the audio is about 5 seconds ahead of the video!I defragged the drive thinking that it would fox it and it didnt the only way I figure is that by dropping all that data it corrupted the video file. Because before the freeze up the a/v are in perfect sync.
Would using something like partition magic to make an area of the drive a separate drive help since it wouldnt beinterrupted by windows or other things on the drive.
Results 1 to 1 of 1
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Ok using the new DivX release, how do i capture, HD style?
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 9th May 2009, 23:35 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
DivX to DivX Convertion Problem
By Spiderm@n in forum Video ConversionReplies: 25Last Post: 4th Dec 2007, 05:15
