I am using the ISObuster to try and convert .dat files that I have on disc to a .mpeg file that is needed for my Easy CD creator to burn it. Everytime I use ISObuster, the files are still left in a .dat format. Any suggestions on how to conver a .dat file would be very helpful. Thanks!!
Hello,
With isobuster when you save it you have to save it as "filename.MPG. You have to tell it to change the file name. Your striping the video portion out and making it an mpeg file.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 16:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 27th Sep 2008, 00:18 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 05:24
