I am using wintv to capture in avi format, using tmpgenc to convert and easy cd creator to burn vcds. Problem: I always get a red "x" next to "SYSTEM CLOCK REFENCE 1084" MEANING IT'S NOT ACCEPTABLE and it cannot be converted to vcd. What is the system clock refence ????
you can still burn it.but if you try to fast forward or rewind the sound will be off.cilck add anyway.
DO NOT CLICK: "add anyway:!
Apply simple de-multiplex and simple multiplex, being certain to use video-cd as your 'type'.
BTW: correct clock reference is 1200.
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 13:34 -
phillips 3575h clock problem
By resohed in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2008, 18:44 -
sync computer clock to broadcast?
By 4evrplan in forum ComputerReplies: 5Last Post: 9th Jul 2008, 16:36 -
Fall for Recorder Clock
By UnknownVT in forum DVD & Blu-ray RecordersReplies: 8Last Post: 12th Nov 2007, 10:06 -
Trutech 1620 clock
By jaybird206 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jun 2007, 15:20
