Results 1 to 10 of 10
  1. Just tried out my first encoding session with CCE (via DVD Rebuilder). I never realised till after it had started that setting it to 2 pass VBR in DVD REbuilder actually only does 1 pass in CCE. Anyway, that's not my question. My question is;
    Is the time it takes to encode for each pass equal?
    For example, the film I just encoded took 192 minutes for 1 pass VBR
    If I was to do a 3 pass VBR encode, would it take 3x192 minutes?
  2. Banned
    May 2003
    Massachusetts
    Pretty much.
  3. That's weird. I performed the same task, with 2 pass VBR on a slightly faster machine and it took 212 minutes.
    canada
    Actually when you choose 1 pass in cce it does 2 pass,the first pass produces the val file and then the second pass it starts to produce the mpv file.So if you choose 3 pass it will take 4x the amount it does for cbr encoding.So it would take 4x96 minutes to produce your file.
  5. Hi. I just tried using CCE with Rebuilder also. I noticed the my CPU temp shot up while CCE was doing its thing. Can someone tell me if this is normal?
  6. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    yes. encoding shoots your cpu to 100% usage. anywhere between 2 and 10 degrees C is a normal change.
  7. Thanks, flaninacupboard for the reply. My CPU temp is normally around 100F, but while CCE is working and the machine is under a full load it is about 126F. I am worried about damaging the CPU since CCE takes a couple of hours.
  8. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    that temperature is nothing to worry about at all. mine will regularly reach 149f on a warm day, and chips today are good up to about 165f.
  9. Thanks again for the info
    I think that rebuilder does not do the encoding passes as it really is. For example when you choose 2 passes it does the vaf and 1 pass. If you choose 4 passes it does the vaf and 3 passes.
