hiya
i am thinking of upgrading my old nec1300a for one of these dual layer burners and just wondered what you guys are using,i could always upgrade to an 8x burner but i think i will invest in a dual layer.
are they worth upgrading to yet or is it a waiting game.
are the discs available yet or are they expensive.
just wan't some light shed on the it.
cheers
..............dave
Results 1 to 14 of 14
you can get an 8x speed dual layer burner for 79.00 bucks, you might as well go for it
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=924345&Sku=M199-1008
this is made by necmember since 1843 -
Try the words dual layer, media and burner in the search box.
Before I would even consider buying a dual layer burner it would have to allow bitsetting.
But more importantly, the media has to drop significantly in price. I will not pay more than $2 for dual layer media. And given the cost of single layer media, there's no reason anybody should.
Last Thanksgiving I "upgraded" from my 3 year old 1x -R/Ram burner. I bought a 4x +/-/RW burner at Staples for $100 after rebate. The piece of shit lasted four months.
Now I am back to burning DVDs at 1x with my old burner. Not a big deal since I don't burn many DVDs. But I'm not all that anxious to spend $ on a another burner yet.
Actually, I bought a DVD Drive and an office phone at Staples. I even made the mistake of buying some Staples CD-Rs- all of it was junk.
Almost everything I've purchased at Staples was junk. At least I've finally learned my lesson. I avoid Staples like the plague. -
I just bought a liteon dual layer off of newegg and I love it. It was $80 and there were no rebates to send in. Cost like 11 shipping so totalled $91.00. Best buy wanted $179.00 for the same burner. Just burned my dual layer with DVD Author and it worked wonderful. Might want to look at newegg for the liteon. I originally went to buy the Sony that best buy had for $139 after rebate but the guy as best buy or the geek squad told me that liteon does a better job of copying dvd's. says the sony was a hit or miss. Just what I heard. Good Luck
the media is expensive and i have heard not all dvd drives can read what has been burnt.
is it worth waiting untill it gets a bit more understood
...................dave -
Originally Posted by monkijin
If I were you, I'd keep the NEC (which is a capable burner) until DL matures. I'm keeping my Pio 106 until the price is right.
Best of Luck,
-Evan- -
If you do a lot of +R media the Liteon 812S is a great deal at Newegg, $68 free shipping, and the guys at http://codeguys.rpc1.org/index.html have a great firmware update to 832S dual layer. It works well with RICOHJPNR01 media and OK with Prodisc S03 -R. Also does bitsetting.
Not the greatest burner for -R but a LOT of firmware support.Still a few bugs in the system... -
Originally Posted by QuaiBoy
i,ll stick with my old nec untill it starts to play up.
thanks for your input people appreciated.
..........................dave -
Get a pioneer 108, 16x dvd writes & 4 x dl writes, 8x media writes @16x & oh, 4x dl media comes in January (yes, january) Just $129 oem.
Reports on 12x and 16x burning on the 108 aren't good. 108 burning at 16x is slower than 12x on some other writers. The NEC has the same specs. May or may not be any better. NEC and Pioneer both talk about writing 4x DL with 2.4 media, although it's probably about as hit or miss as writing at 8x with 4x SL media.
Nothing can stop me now, 'cause I don't care anymore. -
Originally Posted by ViRaL1
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer DVD Burner Use
By Aristocles in forum Newbie / General discussionsReplies: 4Last Post: 15th Oct 2009, 01:11 -
Is TS-H552D a dual layer burner?
By revjeff in forum DVD & Blu-ray WritersReplies: 5Last Post: 30th Jun 2008, 20:17 -
DVD Burner for writing Dual Layer
By StealthKing in forum DVD & Blu-ray WritersReplies: 9Last Post: 1st Feb 2008, 21:25 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
