Well this actually is capture related b/c I'd like to keep the system on low power while I'm away, and then automatically do a timed capture. But even if I don't do that I'd like this problem fixed. Anyway, there are some irritating problems that sometimes\often occur with standby/hibernate:
-system goes to low power, and a few minutes later exits back to windows and goes back to normal power with no user provocation
-system locks up when exiting low power mode
If anyone has any advice I'd appreciate it.
Turn off the power save mode stuff in the control panel
Under screen saver settings, click power options, turn off all the hibernate and hard drive options.
Other than maybe your power supply is dying
Dell Monitor goes into Standby mode
By Soixante in forum ComputerReplies: 8Last Post: 17th Dec 2011, 08:35 -
Do you shutdown your computer, leave it on, or put it in standby?
By yoda313 in forum PollsReplies: 21Last Post: 7th Aug 2008, 16:21 -
Samsung P171 STANDBY
By ionutzcena in forum DVD & Blu-ray RecordersReplies: 0Last Post: 3rd Aug 2008, 03:51 -
Hibernate function unavailable / not working
By denali in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Apr 2008, 14:59 -
Hibernate setup
By ranchhand in forum ComputerReplies: 14Last Post: 2nd Jul 2007, 11:51
