Hi, can anyone help me on this small but annoying problem?
OK, i've just transcoded some avi's over to mpeg2 using the 16:9DAR flag in CCESP (the AR of the avi's where 16:9....1:1.77) created the menu's in TDA burnt the DVD and played on my telly. The encoding is superb and fills up my screen lovely in 16:9 mode (its a Phillips w/s telly). The problem is when using the menu's in 16:9 mode I CANNOT SEE the return to MAIN MENU button (as its just off the screen, at the bottom) but I can see it in 4:3 mode or SuperZoom mode etc.
So is there a 16:9 flag for doing the menu's in TDA or is it crap and stuck at 4:3 (pretty pointless if it is...as it means changing modes on the telly to use the menu's).
PS. if anyone wants to know.... the original avi's where 512 X 288 which I then upped to 720 X 416 with an 80 top and bottom border (PAL) using AVIScript to CCESP 2.62.
Was doubtful of the end result as I thought I may have resized to far but WOW the results are fantastic the video is clean and artifact free and looks better than playing the original avi's on my Yamada mpeg4 DVD player. I did a 2 pass VBR 16:9 DAR with a 1000min-5500max and 3400 ave as I had to fit six 30min avi's (of the same res) onto a single DVD...oh and the audio is set at 160 in mp2 (for what its worth).
Results 1 to 1 of 1
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 14:19 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 18:43
