i just bought all these memorex dvd-r's that i thought were real nice and started burning all my ripped dvd's onto them bc old ones were kinda messed up (shitty dvd's). Anyways, i burned all my dvd's and tested them on my computer to make sure they worked but then they didn't work on my dvd player! what a waste of 30 bucks...but here's the WEIRD thing. I burned all these dvd's at 1x and they didn't work, i use the same DVD's and burn at a higher speed and they work. this info is too late to save my dvd collection but does this make sense at all? or is this just coincidental? is there anyway to make my dvd player play these??? i appreciate any ideas on the subject thanx!
There are two schools of thought on this. One says burning slower can produce deeper and more reliable burns because the surface is under the laser for longer. The other says that burning at full speed is more reliable because the stability of the tracking is higher at these speeds.
So what does this prove - f*&ked if I know, but if burning at higher speeds works for you, go fo it. -
Actually one school of thought is that at 1x you get 'overburnt' discs. Many discs no longer support 1x as a burning speed... and many burners won't let you burn at 1x any more.
It happened with CD's - modern CD burners won't go below about 8x.
- Gurm -
Plus drives also use different write strategies for different speeds.
Blah, blah, blah
Win7: slow down dvd speed
By themaster1 in forum ComputerReplies: 4Last Post: 1st Jan 2012, 19:03 -
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 00:46 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 15:37 -
Ativa 18x dvd writer is real slow and tried everything to speed it up!!
By rotwiler in forum DVD & Blu-ray WritersReplies: 6Last Post: 13th May 2007, 00:21
