I have several movies in AVI format and they are DIVX...the
Quality is very nice...When I play them on the computer they are in Wide Screen Format (The whole screen is not filled with the video)...and that is fine, because the quality is excellent....however...when I convert the AVI to a VCD to watch the AVI video on my DVD player...the Encoding Process takes the Wide Screen Video and stretches the video and makes the video on the DVD player...look like
crap...very unwatchable...So my question to anyone, is how do I convert the AVI file to a VCD file while maintaining the Original Screen Size? I have tried several Encoders...but no luck? HELP..thanks
<font size=-1>[ This Message was edited by: jeriksen on 2001-11-18 22:24:30 ]</font>
ok you are encoding to vcd, not really good since vcd sucks with bad quality.
If i were u, either encode to multiple cds with svcd standard, or if you only want 1 cd(like me), encode to xsvcd with AWESOME quality.
Now on to your answer-
When you choose mpeg=2 stream and mpeg-2 program VBR, for your video tab res settings- you have a few choices.
1- 352x240
2-480x480 (ultra damn widescreen, too much for me)
3-704x480
In my opinion, i always use 352x240 then do something different to keep it widescreen
While still in video tab, choose 4:3 display then go to advanced tab
in filter section, double click clip frame.
In there, choose full screen, keep aspect ratio. If it looks awesome now, then just hit ok and set whatever else and encode like that. If it is not ok, do this-
In clip frame, choose center(custom size)
Manually adjust the inside res the way u want it.
REMEMBER- YOU WILL NEED A SMALL BLACK BORDER AROUND THE WHOLE MOVIE. If you don't, part of the movie will be cut off -
What program should I use...or do you recommend that I use
for encoding....Can I make a xsvcd from Nero ? -
sean madison, your reply is not justfied, he is using DivX as source, encoding to XVCD or X anything will produce a much worse quality then VCD when using low quality source, all his question was how to fix the Wide Screen issue.
jeriksen, when you encode using TMPGEnc, go to the Settings and Advanced, and set the following to retain the Wide Screen format so the picture will not be stretched:
Source aspect ratio = 16:9 Display
Video arrange method= Full screen (keep aspect ratio 2)
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Thanks a lot...I have been waiting for an answer to that
question for a long time now....Thanks again for that info.
laptop screen size too big
By angryassdrummer in forum ComputerReplies: 7Last Post: 14th Feb 2011, 23:20 -
Does a DVD have to be compliant, as far as screen size?
By snafubaby in forum Authoring (DVD)Replies: 8Last Post: 25th Oct 2010, 00:18 -
Different screen size with different browsers
By disturbed1 in forum FeedbackReplies: 5Last Post: 27th Nov 2009, 06:10 -
16:9 Screen Size Question
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2007, 19:43 -
what screen size for video in phone???
By askformore in forum Portable VideoReplies: 1Last Post: 6th May 2007, 20:24
