Okay, I downloaded an mpeg file and here is the info that the program AVIcodec returned on the file:
I keep getting the dreaded "file unsupported" error in TMPGEnc when I try to convert the file to DVD compliant Mpeg2. I've done everything the sticky post suggested such as:
1. Make the Directshow Multimedia File Reader the top priorty
2. Installed DivX codecs
3. Installed XviD codecs
4. Installed ffdshow codecs
But I still receive the error. Any other suggestions? Thanks.
Live Long, Play Hard, Think BIG!
That is already a DVD compliant file if AVIcodec is correct. It doesn't need conversion. However it is shown as 20 seconds duration with a file size of close to 20megs.
You don't need XVID or DIVX unless that's what you plan to convert it to. If so I would use VirtualdubMod instead.
My DR-DX5 has the dreaded non-descript "loading" error.
By Cyrax9 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 19th Feb 2011, 21:38 -
Panasonic ES25 dreaded U61 error message; fix?
By padraig in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Aug 2010, 15:54 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 18:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 21:31 -
AutoGK Error - Unsupported audio type
By bjblackmore in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 20:19
