can some1 recommend me a program that converts avi's or mpg to animated gifs?
thanks!
Results 1 to 9 of 9
There may be programs out there that do just that, but I do mine manually. I extract the frames, bring them into Photoshop, edit them, then import into ImageReady to convert into animated GIFs.
Here is one I did from some video footage of me racing. I had to crop and reduce quality to get it under the 50 kb limit:
Here is one I did from a still picture:
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
You can use your Video editor, but I like to use VirtualDub-Mod. It works great with Mpegs. You can also use PowerDVD too.
trying to use virtualdubmod right now... so i open up a clip, go to file/save image sequence?
but i am getting way more frames than i want =P is there an option to decrease the frame taking interval? or do i have to just manually pick out which frames I want for my gif? -
I usually extract one frame at a time. I select the frame I want, then I hit Control + 1 to save image to clipboard. I then paste the image in my Image editor. Depending on the animation you want to make, you'll probably use anyware from 1 - 5 frames.
I use Jasc's Animation Shop. You can open video files in there and save it as a .gif animation. You can also decrease or increase the speed, add text, etc. It comes with Paint Shop Pro, and you can download the trial version at http://www.jasc.com.
Another thing that you can try is to trim around the piece of the clip you need, then save as an image sequence.
Please recommend good freeware to convert video to animated gif.
By zlmdlo in forum Video ConversionReplies: 1Last Post: 11th Jan 2012, 06:27 -
What's a good program for converting MKVs on a Mac?
By Crossdive in forum MacReplies: 6Last Post: 4th May 2011, 06:01 -
Video to .gif converters? (animated gifs)
By Hank Kinsley in forum EditingReplies: 1Last Post: 31st Aug 2010, 00:13 -
Searching for a Program for Syncing Music to Video clips.
By benjzx in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2010, 21:12 -
Easy way to resize animated .gifs?
By Ai Haibara in forum ComputerReplies: 31Last Post: 10th Jan 2010, 00:30
