Hi all. Thanks in advance for your help.
Looking for best media compatibility with the Pioneer 106. Not many recommendations in the media lists so looking into what works for people right now. Automated data backups only, probably less than 2-3GB at a time. Discs will be used once a week each (5 discs, M-F rotation), completely wiped before writing. May more to a 107 eventually, so 4x media is a pro but quality 2x will also be looked at.
Also, if you use unattended backup software compatible with DVD-RW drives and Windows 2000 Pro and have good results please share your experiences.
Thanks again,
-Evan-
Results 1 to 1 of 1
need free software recommendation for cutting and joining media files
By xyz123 in forum EditingReplies: 1Last Post: 20th Aug 2011, 04:41 -
VCR Recommendation?
By tonyaldr in forum DVD & Blu-ray RecordersReplies: 9Last Post: 17th Mar 2008, 16:03 -
looking for recommendation for codecs
By pike8 in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2008, 08:14 -
Need recommendation for printable media
By fazza8 in forum MediaReplies: 0Last Post: 23rd Nov 2007, 16:10 -
Need a recommendation
By berfles in forum Authoring (DVD)Replies: 1Last Post: 4th Jul 2007, 03:21
