Whats the best dvd burning software for backing up ps2 games and creating dvd's from mpegs. Im buying a dvdrw without software, i have one of the latest nero's but it has no dvd option in the panel, just vcd and svcd. I presume i need a plug in, or is there better software to use?
Thank you,
Andrew
For authoring i personally like DVD Movie Factory from Ulead... simple and fast and does not re-encode compliant MPEG's.
For copying DVD's use an updated copy of NERO or Roxio general purpose copying / duplication software. (roxio 6 basic came with my burner).
If the PS2 games are not protected any copy program will copy them just fine... if they are protected you can use CloneDVD or Intervideo DVDcopy. (with a copy of AnyDVD or decrypter) I am not sure on the format of PS2 games.. maybe a few searches are in order. -
I have been using Alcohol 120% to copy my PS2 Game's, a beta version of CloneCD is avalible to download and try it out. I used it on a couple of PS/2 DVD's games yesterday, it work fine.
http://static.slysoft.com/beta/SetupCloneCD5000.exe -
Nero 5.5 is rock solid for me, too.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
When you install your dvdrw nero will show a pulldown tab and you can select dvd recording,i use nero to burn my ps2 backups and thay work better than if i burned them with alcohol 120%.
I don't know about the best however I can recommend the following for problem free backups.
1. Use Shrink to re-author and backup.
2. Use imgTool Classic and make an ISO image.
3. Burn with DVD Decriptor.
No coasters, no skips and a backup that is hard pick from the original DVD, more importantly, I use the cheapest DVD media I can find.
The above mentioned software are all free downloads.
The best DVD burning software
By tarzan54 in forum DVD RippingReplies: 22Last Post: 1st May 2012, 05:11 -
By ingeborgdot in forum DVD RippingReplies: 6Last Post: 17th Sep 2011, 14:10 -
Need Quality DVD Burning Software?
By BassJunkie in forum DVD RippingReplies: 2Last Post: 7th Jul 2009, 10:11 -
Looking for DVD Burning Software!
By mats.hogberg in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 09:52 -
Best DVD Burning Software for flagging 16:9?
By markannab in forum Authoring (DVD)Replies: 17Last Post: 4th Jun 2007, 13:09
