Thread: Video + DATA on one dvd
  1. #1
    Hi All
    I want to put a dvd slideshow and a data folder with the pictures on the same DVD. Is this possible. If so how and with what software?
    Thanx in advance
    comfy
    Member
    May 2004
    USA
    Posts
    2,003
    Some of DVD Authoring software I have also throws on the DVD another folder 'off the root' of the DVD that includes data files associated with your job.
    So, you could add another folder to your dvd contents on your hdrive and when burned it should copy that folder along with your other VIDEO_ folders and files... never tried it but it should work ok
    Member yoda313's Avatar
    Jun 2004
    The Animus
    Posts
    21,013
    Hello,
    DVD_Ripper-So, you could add another folder to your dvd contents on your hdrive and when burned it should copy that folder along with your other VIDEO_ folders and files... never tried it but it should work ok
    BINGO! That will work. DVD players only look for the video_ts folder. All others are ignored (dvd-audio uses audio_ts). As long as you have enough space on the disc add as many folders as you want (as long as there not named video_ts ).
    Kevin
  1. DVD-Video with Data Inclusion
    By Axvon in forum Authoring (DVD)
    Last Post: 16th Oct 2011, 10:53
  2. How to combine video data and audio data in realtime
    By mudassar in forum Video Streaming Downloading
    Last Post: 31st Aug 2010, 08:00
  3. Data files into a Video DVD
    By galactica in forum Mac
    Last Post: 19th Jun 2009, 08:16
  4. How to safely add user data folder to DVD Video?
    By fvisagie in forum Authoring (DVD)
    Last Post: 1st Oct 2008, 06:32
  5. Burning VIDEO_TS folder to a DVD disc as Video not Data
    By xtaint in forum Authoring (DVD)
    Last Post: 3rd Aug 2008, 08:23
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
