Hi ive decided to purchase a sony DRU-510A dvdrw so i can make ntsc dvd's like the ones i buy and play on my pal tv fine...now i just have one question. Do you have to telecline during the conversion from 23.976fps to 29fps or do you just convert to 23.976fps and burn it in ntsc format and let the software do it? I presume that if i create a standard ntsc compliant dvd i wont have these issues and they are so cheap now so.
Thank you,
Andrew
Results 1 to 1 of 1
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
NTSC DV from Final Cut Pro to NTSC DVD Problems
By Killer3737 in forum Video ConversionReplies: 1Last Post: 9th May 2011, 12:25 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
Do I use NTSC or NTSC-movie in DVD Flick?
By Belfour in forum Authoring (DVD)Replies: 1Last Post: 15th Sep 2008, 10:11 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
