hey..
does virtual dub have a batch encoder like TMPGEnc?
if there is a batch encoder, how do you set the settings for it so that you can run it? like how to set the video compression settings and the audio settings?
thx alot
VirtualDub does have a batch encoder. Set up everything and when you go to Save AVI, tick the box down the bottom that says "Don't run this job now...". Repeat this for all the videos you want to batch. Then go to File > Job Control and your batches will be set up.
If in doubt, Google it. -
How then do you get it to where you can batch frameserve to TMPGEnc's batch?
For example, if you have 5 videos you want to encode and want to frameserve all of them through VirtualDub, how do you get it to where you can batch them and set them up so that each of those 5 videos is encoded through TMPGEnc batch?
TMPGEnc batch runs first [.tpr] --> Looks for [.vdr] for first video
TMPGEnc batch runs second [.tpr] --> Looks for [.vdr] for second video
etc.
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub Conversion Question
By zenzen1 in forum Video ConversionReplies: 14Last Post: 11th Apr 2009, 09:15 -
Virtual Dub 1.8.5 Editing question
By zenzen1 in forum EditingReplies: 3Last Post: 27th Sep 2008, 04:55 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36
