The clips that I have are 352x240 MPEG 1 (VCD).
I have added several of these clips in the timeline but when I try to play/preview it on the "Program" side of the video window, it skips and lags a lot. Even though it plays smoothly on the "Source" side.
Does anyone know which settings I need to configure in order to edit/play properly on the "Source" side?
Results 1 to 20 of 20
Where can I find that option at? Sorry, I'm a Premiere newbie.Originally Posted by pchan
Go to your Monitor window and right-click. Select Monitor Window Options and you should select the proper timecode.
For PAL, you should select 25 fps Timecode. -
I selected different Timecodes but it didn't change anything on the "Program" side. Unfortunately, it still skips.Originally Posted by pchan
Could it be because the clips are compressed as MPEG1?
I heard Premiere is really slow working with compressed video files. ??? -
That could be the problem. You might want to find a way to convert the mpeg to an AVI file.
Have you tried rendering the work area before previewing?-mojo-
http://mpmediaproductions.tripod.com (old site with stuff)
http://www.mpmediaproductions.com (official site, being designed)
http://www.paulinasdesigns.com (current project) -
Preview only works well with low or uncompressed AVI
Premiere Pro has a MainConcept plugin that can be bought, but not sure if it helpsWant my help? Ask here! (not via PM!)
Even "Rendering the work area" didn't change anything. And it took a really long time too.Originally Posted by mojo2185
Does Premiere Pro have the problem handling MPEG files as well?Originally Posted by lordsmurf
So basically it's impossible to edit MPEG files with Premiere? I'm a bit disappointed. That's strange because the MPEG1 file is pretty low quality and yet it has trouble handling it. But I guess it was designed to smoothly preview/edit AVI that are gigs.
I guess the only option for me is to convert the mpeg files to AVI with TMPGEnc and then edit from there. It would be a bit time consuming to encode back and forth though. -
Do not capture MPEG if you want to edit. If you have an MPEG card only, then you need to buy an AVI card.
I use Premiere 6.5 exclusively for my video editing. I have no problem editing MGEG1/2 and Divx files. Of couse, I have all the encoder install. As for your case, I notice that your video clip is 352 x 240 so it's NTSC. Set all your frame rate to 30 fps.
Another area to look at is the Clip Speed setting. Go to your project folder and click on one of the clips. Press Control + Shift + R. A Clip Speed window will pop out. If the New Rate is not 100%... set it to 100%. (Less than 100% will slow down the clip, >100% will speed up the clip and negative will reverse the clip)
One more thing to do is to make you have all the frame rate setting at 30 fps. Go to Project > Setting Viewer. In the Frame Rate row, you should see all 30 fps. -
Well, my capture card does AVI only. These clips that I wanted to edit, I had converted to MPEG because the AVI files were taking up so much space. And I thought I would able to edit the compressed MPEG files (I didn't really care about quality) with Premiere. I guess I'll need to buy lots and lots of hard space since Premiere works well only with uncompressed video files.Originally Posted by lordsmurf
Wow, even DivX files?Originally Posted by pchan
It was already set as 100%. And actually the MPEG files are 29.97 FPS. I played around with different frame rates but it's still the same. -
Yes, Divx too. I have a PVR (PC + TVcard + Showshifter) and all clips are capture in DIVX format.
One more thing to check. Go to your Project window and right click and select properties. All your clips show 29.97 fps ? -
Yeah.Originally Posted by pchan
File Size: 184.49MB bytes
Total Duration: 0;18;28;18
Average Data Rate: 170.42KB per second
Image Size: 352 x 240
Pixel Depth: 0 bits
Frame Rate: 29.97 fps
Audio: 44100 Hz - 16 bit - Stereo
OK. Go to your device manager and check if the DMA for the IDE drives are turn on.
I think so. It's set as "DMA if available" and says Ultra DMA Mode 2 for primary IDE channel. Just wondering, what does this have to do with it?Originally Posted by pchan
Just my personal experience that if the DMA is not turn on. The video playback will be jerky. It looks like all that need to be checked has beed checked. Just a note. When you start Premiere, you select DV-NTSC in the Load Project Setting Window I suppose.
By the way, you are using Premiere 6.5 I suppose. There is a slightly different setting in Premiere 6.0. If you are using Premiere 6.5, then you can export your timelines to VCD and see if it's OK.
Here is how you export the Timelines.
File > Export Timelines > Adobe MPEG Encoder. Select the proper setting for NTSC VCD and go for a TV break or something. If your output file plays OK, then it's OK.
It's Saturday morning in my area. Got to bring my kids out. Have fun ! -
Actually, I already tried exporting the timeline and it skipped a lot just like the preview.
Please check again your project setting. It must all be the same Frame Rate i.e. 29.97. If all the same, then I suggest you grab a clip from any VCD disk and try out the whole process again. I still suspect that your video clip source may be the problem.
VirtualDub doesn't play audio in preview
By Sebastian2011 in forum EditingReplies: 20Last Post: 19th Mar 2012, 04:33 -
Unable to play asset in preview window
By gstewart in forum Newbie / General discussionsReplies: 2Last Post: 3rd May 2010, 19:04 -
Info, Play and Preview buttons dead (AVI to DVD ffmeg mpeg2)
By MsMousette in forum ffmpegX general discussionReplies: 11Last Post: 14th Apr 2010, 20:58 -
video back and forth in preview (premiere CS4)
By george2005 in forum EditingReplies: 1Last Post: 24th Mar 2010, 23:18 -
Timeline Preview - Vegas Pro 8 vs. Premiere CS3
By SCDVD in forum EditingReplies: 2Last Post: 15th Aug 2008, 12:29
