I keep getting errors, thought it was me but my friend is having the same problem. We use DVD Shrink or Clone DVD make our backups. Then when we try and make a backup of the copy I'm getting Redundanacy Cycle Errors I have tried Copying the CD in Winxp, using Clone DVD, and tried DVDInfo and a ISO copy but get an error after it finished, something wrong with the ISO File.
We use Sony DVD's, Maxell dvd, Memorex DVD, Matrix DVD and DVD's from Fry's.
Same problem on all.
Is there something we need to do while making the 1st backup in DVD Shrink or Clone dvd??????
We are stumped.
Do your backups work? I mean your first backup? My kids like to
destroy discs, so I have made backups of backups - if they totally
destroyed one, I have to find the originals and start from scratch,
but even slightly scratched discs, you can make a new copy. I use
dvd decrypter, copy the files and just burn as though it was my
original. No problems at all. -
After backing up your dvd to your harddrive with DVDShrink, use nero to burn it by copying the stuff in the VIDEO_TS folder to the VIDEO_TS folder in nero. Verify it before burning in it nero if you run into problems then there is something wrong with your back up. If your backing up the whole cd and not changing anything then use the full disk guide from here. http://www.dvdshrink.info/guides.php
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 05:35 -
How to get my BluRay HD backups to PS3
By gga in forum Blu-ray RippingReplies: 6Last Post: 13th Feb 2009, 18:43 -
DVDFab and Playstation2 backups
By kdroskinis in forum Newbie / General discussionsReplies: 7Last Post: 9th Aug 2008, 01:24 -
Looking for best way to compress dvd backups
By Wolfsrudel in forum Video ConversionReplies: 8Last Post: 2nd Jan 2008, 14:36 -
The Importance of Backups
By Soopafresh in forum ComputerReplies: 11Last Post: 9th Sep 2007, 18:31
