  1. im trying to hardsub a movie using virtualdub subtitler, i load the xvid movie, then load the subtitle (.ssa) using video>filter>subtitler, then file>save avi, after than i got an error
    "Cannot start filter 'subtitler': Original subtitling Y resolution is unreasonably small"
    any ideas how to fix this?
    Apr 2002
    The State of Frustration
    Where did the subtitle come from, and can it be displayed on SSA?
    Hello.
  3. the subtitle is originally a .sub, i converted it to .ssa using subremux because .ssa is the only subtitle recognized by subtitler
    i played the xvid movie using bsplayer and load the .ssa subtitle, it displayed and no problem with it
  4. need help here guys
  5. nodoby knows?
  6. haha, i solved my own problem
    i viewed the .ssa file and found out that the
    PlayResX and PlayResY has value of 0, so i thought this could be causing the problem, i check other .ssa files that i have and found out that their values is not 0 but some number, i borrowed one of my .ssa files PlayResX and PlayResY and it worked.
