Hi! I've been trying to convert DVD DTS files to 6 seperate wave files, but the problem I'm having is is that when I go to the InterVideo Audio Decoder properties settings, the only channel options available are DOLBY_SURROUND and S/PDIF output.
Where can I get a file that allows me to use 5.1/6-channel output with the InterVideo Audio Decoder settings?
Any help would be appreciated, please and thanks.
I think you might be taking the hard way here. If you still have the original dvd with the dts files on it, just use the program DVD Audio Extractor and it will do it autmatically for you.
Does AC3 & DTSOriginally Posted by dark_myuutwo
http://ac3filter.sourceforge.net/download/ac3filter_1_01a_rc5.exe
(Instead of InterVideo Audio Decoder)
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
How can I make a .dts from wav's ?
By Robertus in forum AudioReplies: 2Last Post: 5th Jul 2010, 16:20 -
Editing/Trimming a DTS Wav
By ranosb in forum AudioReplies: 12Last Post: 21st Jul 2009, 03:06 -
6-Channel Wav to AC3 and DTS
By kerpal in forum AudioReplies: 8Last Post: 9th Feb 2009, 10:10 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 04:23
