I have a Duplicator with the Pioneer A07/107 and firmware of 1.13 ---- Should I upgrade the bios on this thing, or is it fine with this version? I am mainly using Ritek G04's. Was wanting to go to the G05's pretty soon...
Since it is a standalone unit, just how do you proceed to do the update? It has a function for "update bios" - would it just install from a basic downloaded file???
THANKS!
Richard
I'm a proponent of "if nothing's broke, don't mess with it".
If the burner's working fine and you have a low amount of coasters with the media you use, why change? I'd burn a few of the G05s and run some scans to see what the burn quality looks like. If it's below DVD-R writing spec or considerably worse than the G04s, then try a f/w update. A buddy I hooked up with a 107 is switching from G04s to TY and MCC 8x next week. If you're interested, I'll let you know how that goes.
Best of Luck,
-Evan- -
Thanks! I appreciate the info...I was also thinking of getting some Ty's...
Richard
Pioneer XV-DV313 DVD player & Firmware Update
By Teac23 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Jul 2010, 13:29 -
Pioneer DVR 545 HX-S update firmware
By josef2010 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 17th Nov 2008, 11:25 -
Help, firmware update problem of Pioneer DVR 630HS
By stepw in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Oct 2008, 11:05 -
FYI:Pioneer DVR-115D Firmware Update
By pepegot1 in forum DVD & Blu-ray WritersReplies: 3Last Post: 31st Jan 2008, 12:50 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 04:44
