Hi All...
Can you hook up the SIMA SCC2 Pro Color Corrector to the SIMA CT2 Go DVD Enhancer together? I am just wondering if they would work well together or not. Also, how good of a job do these do on old 8mm and VHS tapes? or am I better off with the DataVideo TBC1000? The SIMA products are sure alot cheaper.
thanks for any help/opinions.
I stopped using the Sima color corrector because it was cropping a percentage of the picture at the right side. I wound up redoing a number of movies. If you have already purchased one, test a recording both with and without and see for yourself.
This doesn't answer your question but I thought you should be aware of a potential problem that might save you some headaches.
Other products like the dazzle?
By darklink502 in forum Video Streaming DownloadingReplies: 3Last Post: 19th Mar 2012, 21:47 -
Sima GODVD CT100
By kenmo in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2011, 05:29 -
TMPGEnc 3.0 products vs new 4.0 products?
By Valnar in forum Authoring (DVD)Replies: 6Last Post: 14th Jan 2009, 16:38 -
What's the difference between these two products?
By Waterkips in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2008, 00:40 -
Sima Godvd Availablity, What's Going On?
By ralfdog in forum RestorationReplies: 1Last Post: 17th Jul 2007, 07:50
