Lordsmurf's guide discusses using MPEG2 DVD setting on the ATI capture cards w/ the Record Cropped Video. Once I did that I noticed that it actually put a black frame around the video. It did remove some of the unused lines at the bottom, but I think it removed more lines than it needs be. Also, does that decrease the bitrate required for equal quality since now you have black surface area on the video?
I thank you guys in advance.
That's right. It reduces the bitrate for the same quality, so you will end up with higher quality and/or lower file sizes in VBR mode. I always enable it when capturing for DVD.
It only covers over the overscan, nothing more. You don't need overscan. It thus allows better bitrate allocation on the actual image.
Cropped Video, Now Need to Encode
By Punkin444 in forum EditingReplies: 9Last Post: 7th Dec 2011, 12:09 -
Blowing 4:3 cropped video to 16:9
By carlmart in forum Video ConversionReplies: 4Last Post: 1st Jun 2011, 10:40 -
I need a DVR that can record without making a menu page
By khicks in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2010, 17:41 -
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 14:09 -
The video is cropped on my TV, subtitles are trimmed/cutted/cuts off
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 15th Dec 2008, 23:22
