I've been working with ulead videostudio 8 and find it does everything I need except when I transfer Digital8 (sony cam, firewire) to PC. I get the "audio out of sync" problem about 30 mins into a 1 hour transfer. I know it's not the PC because I've tried the same transfers with some freeware programs (WinDV) and it doesn't go out of sync.
Since it is a data transfer, is there any reason not to use WinDV for transfer and then bring the AVI into videostudio 8 for editing?
Is all digital transfers to AVI the same quality reguardless of what program is used.
What is videostudios problem?
If WinDV works without audio sync problems then there is no reason not to use it then import the DV AVI into Ulead VideoStudio.
Just make sure you capture in the correct format ... you can do DV AVI Type 1 or DV AVI Type 2
I don't work much with DV AVI but I think Type 2 is the one you want.
Are you transferring tapes or are you doing pass-through?
Digital 8mm in a Sony digital 8.
I think since 2 programs work and videostudio 8 doesn't, ita software problem. -
There is a studio 8 update/patch on thier website that is supposed to deal with the audio sync problem, mabey give that a try.
CSS : Confusing as ever...help??
By beavereater in forum ComputerReplies: 2Last Post: 8th Jun 2011, 02:25 -
Converting MP4 to AVI - Confusing Audio Problem
By visibility in forum Video ConversionReplies: 4Last Post: 29th Aug 2010, 18:02 -
AVI.net a confusing problem : using DivX instead of XVID
By Alterego in forum DVD RippingReplies: 5Last Post: 17th Jun 2009, 13:39 -
New problem with VHS transfer
By lgh529 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2008, 22:02 -
Confusing Right with Left...
By Thortok2000 in forum Capturing and VCRReplies: 1Last Post: 29th May 2007, 10:50
