Hi,
I have several music videos in AVI format with the audio in mp3 128 kbps 44100 Hz.
I convert the video to dvd with a superb quality.
The is a little problem, I extract the sound and resample it to 48000 hz with SoundForge.
I keep the sound in PCM format to avoid loosing quality by reencoding the sound.
I can't use cd-audio to replace the sound because there is somme special effects used in the music videos or some speech sequences.
The sound is a little metallic, so is there any filter that can reduce the metallic effect ??
Results 1 to 1 of 1
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
Metallic "chirp" when appending flv segments with flvbind
By brassplyer in forum Video ConversionReplies: 4Last Post: 6th May 2008, 19:14 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
