Hi,
I like to encode my video footage using AC3 audio to have more available space for video in the DVD. How should I do this?
if you use tmpgenc dvd author you can get the ac3 plugin.
FFMPEG/FFMPEGGUI makes good AC3 files for me....you can always run them thru AC3FIX/AC3FIXGUI if required.....play the resulting sound file with a sofware DVD player to check they are OK..I use SONIC because its fussy about its AC3 so if it plays with that it will play on anything.
If you have any problems convert the ORIGINAL audio to a .wav (@ 48khz) with AUDACITY (a bit slow but it ALWAYS works for me ..even on audio files that VDub, BeSweet, etc fail on)....then point FFMPEGGUI at the new .wav.
You could always use MP2 as the end file will be the same size (its less error prone than AC3...but may not play on all DVD players...tho' I've yet to come across one that doesnt play DVD's with MP2 audio...I'm in the UK).
HTH
High-Performance machine taking 20+ Hours to Encode AC3 audio.
By Joe Hill in forum Authoring (DVD)Replies: 9Last Post: 25th Feb 2012, 11:30 -
Video and audio did not encode what can I do?
By IYIasteI2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2011, 11:00 -
Change video, keep audio without re-encode ? Problems with strange AC3.....
By Gwar in forum EditingReplies: 18Last Post: 27th Aug 2011, 09:19 -
Encode my H.264/AC3 .M2TS HD PVR video to Xbox friendly format?
By hopeSOLO in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 13:29 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53
