When I encode 5.1 AC3 AVIs to NTSC DVD, should I be encoding to 23.976 with 3:2 pulldown or to 29.97?
The reason I ask is - although I realize 23.976 with pulldown is preferred, my audio does not sync up properly. I've had fewer problems just encoding straight to 29.97.
Does this make sense or is there something I am missing?
Thanks for any help
The way I do it is:
a) Demux the AC3 with VDubMod (after joining/appending the avi's if spread over more than one file).
B) Run the resulting AC3 file thru a software DVD player to check all is OK (you can also use AC3FIXGUI to check the AC3.... it doesnt hurt to do it anyway).
C) Convert video to (elementary video) m2v with either CCE, TMPG or whatever, at the same frame rate as the original file (23.97)
D) Use PULLDOWN.exe to go from 23.97 to 29.97.
E) Author to an folder (check everythings OK with a Software DVD player..by pointing at the first .ifo file)
F) Burn and play!
Never fails for me.
AC3 audio: 25 to 23.976 fps
By leghorn in forum AudioReplies: 7Last Post: 14th Mar 2012, 02:36 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
avi is 23.97fps,srt is 25fps
By Soixante in forum SubtitleReplies: 7Last Post: 3rd Dec 2008, 15:26 -
Best quality telecine method for 23.976 -> 29.97fps
By DRP in forum Video ConversionReplies: 3Last Post: 11th May 2008, 09:37 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 20:51
