hiya
having problems using dvd decryptor and dvd shrink trying to backup welcome to the jungle,it stops reading on the 4th vob file with each program and comes up with a cyclic redundency check error.
are there any settings to get round this or perhaps another program i can try.
the dvd is brand new and not scratched.
any help would be appreciated.
.......dave
Results 1 to 10 of 10
Cyclic Redundancy Check normally means there are problems reading the disc.
There are many methods around this:
The very first thing is to make sure that there are no fingerprints on the very outer edge of the disc.
Try using Smartripper to rip instead.
Try using a different DVD-ROM or burner to rip.If in doubt, Google it. -
hiya
tried smart ripper with no success however i have managed to back up the dvd to the hard drive using dvd decryptor in ifo mode with the read error setting turned off and have the entire movie so where do i go from here -
Hello,
I believe dvdshrink will read ifo (just open the directory -open file- and it should find it). If not use another transcoder. Since you got it on the harddrive there shouldn't be any problems.
will not do it no matter what i do so i went to my mates over the road and stuck it in his old sony dvd writer and it cracked it without a hickup.
is it hardware related problem if so wot writer do you guys recomend i have an nec nd1300a at the moment which has done everything i have chucked at it so far.
maybe its time for an upgrade.
any idea's as to wot writer to buy please.
thanks for your input it is very appreciated.
.............dave -
just tried to burn the iso and it stops at 75% and nothing happens.
is it copy protected just seems to be a too much a bit of a pain in the rear for me to believe.
.......dave -
A while back, before I had a DVD-ROM to rip with, I came across a disc that my LiteOn 401s wouldn't rip. Same problem, Cyclical Redundancy Error. The disc (side B of The Ten Commandments) was clean & scratch free, as it was new. Side A ripped normally, however, neither Shrink nor Decrypter could rip side B. I threw it my brother's HP 200i & it ripped no problem.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
have tried it my mates sony it rips to hard drive but won,t write it,i will try my other friends plextor see how it goes.
,,,,,,,,,,,,,,,,,,,,,,dave -
tried my friends plextor and has the same problem it actually ripped to the hard drive but you can't burn the image.
must have some sort of encryption on the region 2 pal dvd's here so sod it,fed up with messing around with it anyway now.
cheers for your help everyone.
.........................dave -
sorted...........now have a working backup using dvd shrink.
although very strange considering the amount of backups i have made with no problem.
cheers everyone
....dave
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
