  1. I am currently using a Broadway Pro card for realtime mpeg1 capture. I have the possibility of obtaining a Conopus DV Storm2Pro suite. Can the two cards exist on the same system without incident, (of course only one would be run at a time.) I can't just remove the Broadway as my work flow must continue. Also my Broadway cannot capture past 2 gigs without crashing. Does anyone know a workaround or is it just a hardware limitation? My system is a Pentium 4 3Ghz. 160GB drive and a whole little family of 250GB firewire drives. I source from a JVC SR-VS30 Dual VhS/DV deck via its firewire port. Thanks for keeping the info on this board going. It is the greatest.
    Many thanks,
    Rinkmaster
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    I don't believe that you gonna have any problems.
    Different manufactures / different drivers / different cards for different tasks
    But the only way to really see is it works, is to test it yourself!.
