  1. I downloaded a movie in .AVI format and used TMPGEnc to convert it to MPEG format in order to burn it as a VCD.
    Now, I have no idea what to do with regards to the fact that the file size is about 1.2 GB's and therefore to large to fit on one 700 MB disc.
    So, will NERO or VCDEasy automatically eject the 1st disc and ask me to insert the 2nd one? Or do I have to go through some other process of splitting the file into 2 files?
    I'm lost...
    THANKS!
    PS The VCD guides don't really mention anything about this...
  2. Member Grimey's Avatar
    May 2004
    Canada Eh?
    you could use TMPGEnc mpeg tools to split the file into 2.
    Apr 2002
    The State of Frustration
    You should have used the wizard in my opinion, to know exactly how much to add to each CD.
    Hello.
