  1. Member Wyatt Riot's Avatar
    Nov 2003
    Mankato, MN
    Something chikanakan said in the "desktop db/df" thread got me wondering:
    I've got some great VOB trailers that I want to put on a DVD. I can play them all using VLC, but I can't burn them all to DVD-R (Sizzle says at least one of them has an error, and Toast won't burn both NTSC and PAL VOBs). The error-free NTSC VOBs only take up about 4-5 minutes of video, leaving the bulk of the DVD empty.
    My question is this: can I put the rest of the VOBs on the DVD-R just to store them? It seems that the guides I've followed to backup DVDs say that anything but VIDEO_TS, AUDIO_TS, etc. folders will result in a DVD that won't play on most machines. Of course, commercial DVDs have plenty of executables and such, so I assume it must be possible. Is there a special way that these can be burned along with the standard folders?
    Droplets of yes and no in an ocean of maybe.
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    they can be burned, but they wont be accessed on a standalone player. If you want them to be burned as data then any computer can play them with drag-drop onto the app of choice
    instead of just dropping the vob's into toast or sizzle have you tried demuxing them and then inporting the audio/video components
    just a thought
    Feb 2003
    Calgary, AB Canada
    Some players will play a mini dvd. (my cheap newer set-top plays it, but not my older pioneer)
    (normally authored dvd where the video_ts and audio_ts folders are burned on cdr)
    you would need to demux and then build the dvd, then burn it as a DVD-ROM (UDF) on cd.
    This way it is playable and you won't waste a dvdr.
    just a thought.
