I know that it's possible to build your own pc, but... is it possible to build your own notebook?, If so, do you know a good website where I can purchase the parts?.![]()
Thanks in advance
Not that I have ever seen. I think notebooks are very proprietary as far as the parts they use. Partially because of the small amount of internal space involved. There are a few companies that can 'build' a notebook, such as Gateway. Basically they just give you a few more options like bigger HD or a DVD burner instead of a CD burner.
There are a lot of companies that make notebook computers. You might spend a little time searching for the combo you want. If you can't find it, just wait. Just about any combination should eventually be available. -
I actually found a website that sells notebook parts. I didn't bother to bookmark it, though. I priced out a system and it was more expensive than buying one off the shelf.
Yes and no. You sort of have to be a dealer and sign to order minimal
several hundred units. You can, however, buy what is called a bare bones
laptop to which you add your own CPU, RAM and hard drive.
You don't end up saving money though
Notebook / Laptop Information
By Datson in forum ComputerReplies: 1Last Post: 25th Jan 2012, 09:35 -
Going from desktop to notebook
By Caple in forum ComputerReplies: 11Last Post: 19th Aug 2009, 11:55 -
Capture desktop of another PC/notebook
By cardenal in forum Video Streaming DownloadingReplies: 1Last Post: 26th Jul 2009, 23:55 -
Which notebook you would choose from these 2?
By alintatoc in forum Off topicReplies: 1Last Post: 27th Jan 2009, 22:00 -
notebook problem
By ieh4f in forum ComputerReplies: 4Last Post: 19th Mar 2008, 11:15
