  1. Anyone know how to convert .wmv to dvd+r? I have TMPGenc, but I believe it will only convert to dvd-r....
  2. You could use Stoik WMV-AVI Converter and then TMPGEnc with the DVD2SVCD GUI.
    dvd-r and dvd+r is only the media, it has nothing to do with dvd-video. you are converting to DVD mpeg2 with tmpgenc and then you author and burn dvd-video on a dvd-r or dvd+r.
  4. Originally Posted by Baldrick
    So TMPGenc Plus will convert the video and make it available for burning onto a dvd+r and thats all that I need aside from my burning software? Or do I need something to author with (which I know nothing about as of yet)
    I'm not worried about titles or anything, just the video.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You still need to turn the video into a .vob even if you don't want menus. I've heard you can just rename the final .mpg to .vob and it should work (though I haven't tried it - backup the .mpg if you try that ). You can just use a basic dvd authoring progam and they should let you make a movie only disc (ie auto play the movie only).
    Kevin
