I have 1 big M2V file that I wanted to "insert" chapter (points) in TMPGEnc DVD Author. However, I followed doom9, as well as similar instructions trying to create chapter (points), it still wouldn't work, here's what I did:
1) At Source Setup: Add file, click on that big M2V file, then chose Chapter Cut Edit, and made 5 chapter (points) and clicked OK
2) At Create Menu: Choose Cool 1 as the theme, and there are 2 "pages", first one is Main Menu, and the other is Track Menu
This is where the problem is, under Track Menu, there should be 5 chapter (points) that I created, but it's showing only ONE chapter (point)! Am I missing something here?
I've searched in this forum, somebody suggested making each chapter as separate clip and add as separate clip on Source Setup. That works, and it's showing different chapters in Track Menu, but there's a pause or 1 second lag between each chapter, which I am kind of paranoid about.
Thanks for any advise.
try this. open up your source file and without making any chapter points choose your menu style. then go back to the source setup button and choose edit chapters and make your chapter marks.
Shifting Chapter Point on DVD without reauthoring
By Instant Martian in forum DVD RippingReplies: 4Last Post: 4th Sep 2009, 10:10 -
Placing a chapter point at layer break spot?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2008, 19:02 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04 -
Automatic DVD Chapter Point Insertion
By cw4u in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2007, 00:43 -
Chapter question
By BCbear in forum Authoring (DVD)Replies: 15Last Post: 30th Jun 2007, 08:52
