Greetings,
Which software would you to use to best create super looking motion menu's?
Adobe After Effects, or Adobe Encore?
No contest, absolutely the answer is After Effects. Encore is a DVD authoring program that provides limited menus. If you're going to do anything really cool, you have to do it in PhotoShop or better yet After Effects and bring it into Encore.
While I agree with the previous post, I think it should be pointed out that Encore is a very GOOD authoring program (although it won't hold your hand and isn't automatic); you just need the right tools to create great content for your menus outside of Encore, and then Encore puts it all together. But, no, it won't really facilitate creation of good menus- just "organization."
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Elements 7 - widescreen dvd cut off on the sides
By bigmic789 in forum Video ConversionReplies: 9Last Post: 5th Aug 2011, 08:44 -
MTS and Final Cut / Adobe CS4
By jovannig in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jan 2010, 13:58 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Adobe Production Premium CS3 or Final Cut Studio 2
By spysr in forum EditingReplies: 7Last Post: 26th Feb 2008, 01:51
