Hi,
What program do you guys/gals use to send faxes with?
I want to get a Printer/Scanner/Fax all in one but can't decide which to get. So I thought about faxing through the computer...
Any suggestions??
Results 1 to 12 of 12
i just walk up the stairs to the fax machine
Either the built-in XP faxtools or Classic Phone Tools. They're all pretty much the same these days.
Thanks for thatOriginally Posted by BJ_M
I DON'T HAVE A FAX AND HAVE TO DRIVE 5 BLOCKS FROM HERE AND PAY FOR IT -
Where's that at??? I can't find itOriginally Posted by tekkieman
I have XP pro installed
Nevermind I had to install through the add/remove panel
I think I paid $10 for HotFax. I bought it at Fry's Electronics.
http://www.slipstick.com/addins/services/winxpfax.htm
winXP fax details"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
hmmm what about this,
How do you hook up a fax and an answering machine to the same phone line and have them work properly? SO the answering machine doesn't record the infamous "eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeegongeeeee eegong" or the fax answering to a person.
know what i mean?? -
The Fax Wizard is part of printing. When you are ready to send your document, go to the requester, change the printer to fax, and follow the prompts.
Hello. -
there is a little box you can buy at radio shack that can switch the line to the modem for fax and to the phone for phone ...Originally Posted by 808smokey
or least they used to -- because i have one i no longer use .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Some of the all-in-ones will do it for you. I know of a couple of HP models that do. Phone line runs to the all-in-one, then out to the phone/answering machine. If the call is fax, the all-in-one picks up, if it's voice, it feeds through to the phone. The only thing to remember is to set the number of rings lower on the all-in-one than the answering machine.
edit - some of the pc telephony modems will do it as well.
send video to TV over ethernet?!
By kevbodian in forum Video Streaming DownloadingReplies: 17Last Post: 22nd Dec 2011, 21:13 -
Send image from laptop to TV
By a_2008 in forum DVB / IPTVReplies: 2Last Post: 9th Nov 2010, 06:41 -
Baffled by this one guys 'n gals....
By TheGMan in forum DVD RippingReplies: 5Last Post: 8th May 2008, 08:21 -
How send 1-hr DVD over internet ?
By rdfarr in forum Video ConversionReplies: 11Last Post: 9th Apr 2008, 00:22 -
Send to TAPE (to another PC - Emulation)
By Soreen in forum Video ConversionReplies: 5Last Post: 18th Feb 2008, 11:44
