Hi All,
After I download movies in avi /mpg format , i convert them using TMPGenc to DVD format & then simple de-multiplex them so that they are now movie.m2v & movie.m1v, then I use TMPGenc DVD author to make the Video_TS folder & that completes 1 movie. Now when I try to burn the DVD it takes only 1/2 the DVD space, so was wondering if there is anyway I can burn 2 movies on 1 DVD & have like a menu at start which wil lask me what movie I wamt to play.
Thanks,
On the 'Add File' page of DVD Author, over on the left-hand side, you can add a 2nd track. Add the 2nd movies encoded file(s) to this 2nd track. Then you can make a menu that allows you to select either movie at start-up.
Hi Timmyp,
When I try to add another file into the DVD author as you said...it asks me if I want to replace the existing files as the file names are same...so i tried to call the 2nd movie when it created the video_ts folder as another name, tried to play the files in Powerdvd, it was not recognized.It looks only for the video_ts_.vob names. -
You need to add both movies (and menus etc) BEFORE you create the video_ts folder and it's contents.
import the already created dvd with tmpgenc dvd author, click on add dvd video and open the video_ts folder, add the new movie clips by clicking on add new track and last author a new dvd.
or just import all dvd mpgs(if you haven't deleted them) at same time in tmpgenc dvd author and create a new dvd. -
Do you convert the audio & video at the same time with TMPGEnc ?Originally Posted by pats_2306
As mentioned, go into TMPGEnc DVD Author and put your first clip into the first track. Create a new track and put your second movie into the second track. THen create your menu. Then create the VIDEO_TS folders.If in doubt, Google it.
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 07:31 -
fitting mpg to DVD
By geos in forum Authoring (DVD)Replies: 5Last Post: 21st Dec 2009, 18:54 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 17:53 -
fitting four hours on 4.7 GB DVD
By cthiesen in forum Newbie / General discussionsReplies: 34Last Post: 13th Apr 2008, 17:36 -
fitting more than 1 film on a dvd - help!
By welshgal in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 13:16
