I have a dvd of a mate to convert for him from pal region 4 to pal region 2 as thats all his dvd player will accept is it possible to do this? easy with one program or does it require me to rip it IE mpeg it etc and reburn it?
Please can someone explain the best way to do this?
Hello,
Use dvdshrink or another transcoder and choose ALL REGION. Then burn the video_ts folder. You shouldn't have any issues since your keeping it pal (your just lifting the region restriction).
Just rip the DVD with DVDDecrypter and reburn.
make sure the setting in DVDDecrypter is set to region free. -
Sorry, I just realized DVDDecrypter does not have all region setting.
Just select region 2 in your case. -
Hello,
One note to that, if it's a dual layer disc (ie larger than 4.7gb) you need to shrink it. In that case use a transcoder from the start. If it's a single layer (4.7gb or less) then you can just use dvd decrypter and then burn.Faithful Follower-Just rip the DVD with DVDDecrypter and reburn.
Kevin
Doesn't it have a region 0 setting?? If so choose that one to make it all region, otherwise just use a transcoder and select ALL REGION as I mentioned earlier.Sorry, I just realized DVDDecrypter does not have all region setting.
Just select region 2 in your case.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Ya thanks, if i want to copy dual layer dvds i really need to buy some blank ones as my dvd/rwiter now has dual layer support hehe
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 22:13
