I am getting ready to buy the Panasonic DMR-E75VS DVD-R/VCR combo unit and I noticed it does not have a firewire input. I have a new Sony DV Handycam and want to use that to hook up to the Panasonic but can't I just use the Svideo in instead of the firewire. What will I be loosing by doing this??
Thanks,
Originally Posted by scott_w
I agree. Since you have a miniDV camcorder with firewire, go for a standalone DVDR with firewire.
There are arguments on both sides of this issue, though. You've already read one of them (posted by bugster). The other one goes something like, 'since firewire receives no pre-processing from the recorder, analog produces a better result'. The latter has been argued, ad nauseum I might add, on the likes of the AVS forum (you'll have to draw your own conclusions from that one).
My argument has always been that getting a machine with firewire is a no-lose proposition. You have a choice; you can use firewire OR analog. If it turns out firewire transfers look better to you, then go with that, if not, you're always free to use analog.
So, to answer your specific question, "what you lose" with a machine without firewire (like that Panny) is the CHOICE whether or not to use firewire. Obviously, you simply won't have one; you're stuck with analog, for better or worse.
My Laptop not recognising my camcorder via firewire ?
By topcat0001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Aug 2010, 10:27 -
sony camcorder firewire connection
By rizvii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th May 2009, 23:23 -
Testing Camcorder Firewire Connection
By wacole in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Nov 2007, 10:41 -
Camcorder - Firewire to USB cable
By geek2330 in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2007, 09:29 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 09:20
