I find good quality video files in .avi here and there, but the thing is they are like a mpg file, and only 40 mb lets say for a 4 min music video. Now I dont think its due to compression becuase I havn't found a compressor that can get it down that far. So I'm thinking maybe differnet encodes? Could anyone give me a link to like a basic encode guide maybe? I havnt found one on here but ill keep looking. Even like an all encode site woudl be cool.
Also I have seen like an hour movie in .avi format at 23 mb. Id really like to know how to do that, (it was at good resolution too).
thanks in advance, any help would be appreciated. Im just looking for info on encodes so i know how to do them or somehting (im not to sure on the whole encodeing thing).
I find that extremely hard to swallow, you must be mistakenOriginally Posted by The14thGOD
learn how to convert do divx or xvid for small file & good quality. -
Originally Posted by Treebeard
HAHAAHHAA
THAT IS A GOOD ONE ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hello,
Try the newer divx codecs. I know they include "portable" video bitrate settings. I believe that's meant for those arcos portable digital video viewers and pda's. I don't know how small they get but that would be a good place to start. Look at the dvd to divx guides on this website to get started.
Kevin
P.S. I agree with treebear, how do you get an hour video down to only 23mb???? (Maybe it was encoded at what, 1mbps?
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Oh, my bad, it was 32 mb, dbz movie 6, kazaa.
anyways
thx for the help yoda.
But I have another question, I make my own music vidoes, and I want to get them smaller (my latest, Troy Korn Thoughtless, is 47.9 mb)
so would those dvd to divx work for this since its not dvd...??
thanks in advance -
As your quality requirements are quite vage, I will go out on a limb here and say that smallest you can get is about 1.5 to 2MB per minute (audio included).
Check this out, just skip the rotation step.
-Suntan
Raw MTS files so good, and so small
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 28th Aug 2009, 01:20 -
vdub virtualdub can I combine several small avi files into one
By case310350 in forum EditingReplies: 2Last Post: 5th Jan 2009, 03:23 -
[help] small size good quality
By las7h0p3 in forum Video ConversionReplies: 1Last Post: 6th Nov 2008, 09:27 -
AVI files are too small when copied to a DVD
By lmcnlcy in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2008, 01:44 -
my avi files appear too small on tv...
By vinayak1986 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 23rd Dec 2007, 19:48
