There is a workaround to capture audio with the DAC. I send the audio I want to capture into the DAC along with any video source (like TV). Then I use Scenalyzer to capture only the audio.Originally Posted by Bondiablo
Results 31 to 49 of 49
same here i tried a few black and white films (from TV) and it was fine
the programs or the DAC seem to need a video signel to record anything, but like Michelle says plug it all in and just capture the audio works a treat. or you could just use your sound card after all thats what it's there for. -
In my case, the audio and video equipment is in a different room than the computer. I use an 80 foot FireWire cable. So even though I have a high quality audio card, I end up using the DAC to do most of my audio capturing.
But doesn't such a long lead (80ft) degrade the picture?
Incidentally Michelle, what other software do you use? -
Firewire. That's a purely digital signal. Quality is not related to or dependent on the medium it is stored with or the method that is used to transfer the data. As long as the 80 ft. cable doesn't interrupt or corrupt the digital stream, there would be no way to lose any quality.Originally Posted by Ramon
Cables and connections do have an effect on analog video signals, though. -
fyi: there is an excellent freeware progam called "Vidi" - look around in version tracker
the program works very well with DAC 100 for recording; you can even pre-program the timing
I used it often with DAC 100 to record from cable TV (using the tuner from a video or a DVD recorder) - then I eliminate the advertising and write back to DVD -
An 80ft cable would be a problem if you used it with something like an external hard drive. But DV capture doesn't use the full FireWire bandwidth so it's fine.Originally Posted by Ramon
I use Scenalyzer for capture. -
How much did such a long firewire cable set you back?
TheGame7 - "I am 'The Game' because I am that damn good!" -
Do you need to use a repeater to maintain the rate of transfer?
I will look on eBay - a site I saw sold long cables for 100s of dollars.
I am in the UK though, so I might find it harder...TheGame7 - "I am 'The Game' because I am that damn good!" -
ADS Pyro A/V Link Rev.3 with firmware release 3 is a good alternative. Juts make sure that you got firmware version 3.
For long firewire cable runs you can also use a repeater like this one: http://www.orangemicro.com/repeater.html -
You don't need a repeater for video use.Originally Posted by TheGame7
I think this is the cable I got:
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=197382&is=REG
They sell it for $90. I got lucky on eBay because the seller had listed it several times and kept dropping the price because no one was interested. -
So I won't be as lucky as you and get it for as cheap?
Are their few and far between firewire cables of this length on eBay? Or am I searching for the wrong things?
I need the 6 pin to 4 pin version - will the fact that my ADVC-55 takes power from the firewire port rather than have its own supply effect the data in anyway due to the vast length?TheGame7 - "I am 'The Game' because I am that damn good!" -
Morning all
It's good to know about this limitation (if your bandwidth use requires it to be
at its max) when your wire length requires more than 15' (feet)
** current price is $39 dollars.
So, this little util device could be an option. Thanks.
My problems (though I could use a longer cable, though maybe not a 100' er)
is that the two ends need to be more "elastic". I mean, especially during the
colder months (I woke up this morning to cold 67 degree sunrise inside my
house, but I know it's much colder than that) And, when I turned on my pc,
and went to make coffee, 5 minutes later, I came back to a frozen pc. I know
that, that doesn't make sense (though I've always seem to have this problem)
but I don't know why my pc will freeze on me when my pc is cool or cold.
Anyways, as I was saying..
And, when the cold hits these wires, they become much more stiffer, and hard
to bend/flex them to insert the gizmo into your devices. Because of this, I
have a few wires that are no use to me, because one of the strands of wires
most likely came detatched or something. Anyways. I just wish they would
make the "end connectors" more elastic, say about 3 inches.
Cheers,
-vhelp -
Sorry to drag this up again, but still searching for a long firewire lead on the cheap?
Preferabbly from the UK.
Any advice.?
TG7TheGame7 - "I am 'The Game' because I am that damn good!" -
I bought my DAC-100 here http://www.shopharmony.com/product.asp?i=DATDAC1000 for $179.00 US
I've had for about 6-8 months and I love it. I've captured up to 3 hours straight without a single dropped frame. It works prefect with any capture software I've tried, no drivers to install. Works with Windows Movie Maker, Nero VisionExpress, Adobe Premiere, MainConcept Encoder, Dr.Divx, and several more I can't think of right now.
14Bit/108MHz Video DAC
By siluet in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Sep 2009, 08:43 -
What's a used videodata dac-100 worth?
By zoobie in forum ComputerReplies: 0Last Post: 26th Oct 2008, 02:52 -
Have DAC-100, need HD
By The Waco Kid in forum Capturing and VCRReplies: 0Last Post: 21st Mar 2008, 18:41 -
DATAvideo DAC-15 v.s. other video processer
By perniente in forum RestorationReplies: 0Last Post: 21st Dec 2007, 10:22 -
DAC-100 dip switches
By Steinninn in forum Capturing and VCRReplies: 0Last Post: 6th Dec 2007, 20:31
