does anyone know how i would get a pal mpg vcd file onto a dvd. i have tried tmpenc author and it won't do it, roxio dvd won't do it. anybody know what would work?
she scratches a letter ino a wall made of stone
What type of error message do you get?Is it something like no sequence header?Might be fixable without re-encoding if you mention the problem.
well i get different error messages with different programs, some just freeze up when i try to open the file. tmpenc i get gop too long and something about the pixel size being wrong and just roxio freezes up.
she scratches a letter ino a wall made of stone -
GOP too long is a definite possibility for a VCD compliant file, however pixel size being wrong can't happen if it is VCD compliant, because VCD compliant resolution is also DVD compliant, unless you are trying to add it to a compilation that contains other files with different resolutions.Originally Posted by cheiftombolot
I don't think you can change the GOP without re-encoding. Run your file through TMPGEnc Plus, load a suitable template, and make sure that on the GOP Structure tab, MAX no of frames in a GOP is set to 15.If in doubt, Google it.
Can I burn a .mpg file to a DVD
By robrpb in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 20:56 -
mpg dvd file?
By just in forum Newbie / General discussionsReplies: 7Last Post: 20th Nov 2008, 21:32 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
mpg to dvd keep file size
By bladerunnerx_x in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2007, 13:12 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
