I have no idea where to start, but here goes. About 10 minutes ago my computer went nutty. It started switching to sleep mode and back, and about 5 minutes later it shut off. When it reboot I got this error:
Does this mean it died?![]()
have to tried to install a different version of nvidias drivers? I would do that first. go to their archive of display drivers and grab the not so newest version.
Yah, I already tried that.
That worked until I got to the point of playing games, everything would be fine except for the ground would be blue.
Have you tried it in another computer? Fresh install of OS and drivers?
Have you overclocked this card??
then toss that card and get something that blazes. -
My other computers are a '96 Compaq and a '98 HP, I don't think it's worth my time there.Have you tried it in another computer?
I just did that last night, for hopefully the last time.Fresh install of OS and drivers?
Nah I'm affraid I'd wreck one if I tried.Have you overclocked this card??
I am using the DirectX 9 drivers from Far Cry I think.Make sure you have downloaded and installed the latest Directx drivers
I have a feeling this card is going to be gone soon anyways, the more I hear about it the shittier it becomes.
Is installing a new one hard? My installations go as far as RAM, PCI cards, and hard disks.
Are you using the 61.76 or 61.77 drivers (forceware? If so, I suggest you downgrade to the nice and stable 56.72s.
When I installed the Forceware ones that is when the ground went blue. I guess I am on the older ones, they are the ones that came with it. :P
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 12:30 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48
