I'd like to know if there is a tool, or a way, that I can demux specific VOB IDs inside a group of VOB files.
EX.:
I have VTS_01_0.VOB...VTS_01_5.VOB, where ...0.VOB is my menus, and ...1.VOB to ...5.VOB are my movie files. Inside that sequence of 5 VOBs, I have 3 different movies, but I've got 6 VOB IDs. VOB ID 1 is an intro movie, VOB ID 2 is a Company logo, and VOB ID 3 thru 6 is the main movie... I'd like to use a tool like VOBEdit to demux the last 3 VOB IDs into one m2v file and one ac3 file, but avoiding to demux VOB ID 1 and VOB ID 2.
Is there a way to do it ??? Any help is greatly appreciated
Thanks in advance...
Well, you can use DVD Shrink ReAuthor function to extract only the movie from the DVD.
Hello. -
OK...
I did it with DVDShrink, but I got the same result...
The problem is that the movie is scattered aroud all VOBs. VTS_01_1.VOB contains VOB ID 1, VOB ID 2 and VOB ID 3. VTS_01_2.VOB contains VOB ID 4. VTS_02_3.VOB contains VOB ID 5. The remainind files VTS_01_3.VOB ... VTS_01_5.VOB contains VOB ID 6. How can I make VOBEdit ignore VOB ID 1 and VOB ID 2, and then start at VOB ID 3 and go to the end ???
Thanks 4 you help... -
Demux by VOB ID first. Delete the VOBs with IDs you don't need. Then join the rest. Then demux the videos/audios.
But what Tommyknocker mentioned should work too. If the movie and everything else is part of the same title, you can use the start/end feature to select just the movie.
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Very specific issues with VOB and IFO
By Eve8008 in forum SubtitleReplies: 7Last Post: 5th Aug 2010, 14:23 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
