hi there, i'm looking for a program that can help me convert mpeg's i take off my sony digital camera into a compressed video format that i can send to friends. i used to use windows movie maker becuase it used to have a limit to the output size, but the program has frozen my laptop for the last time.
So I'm just looking for a simple converter than can convert mpegs to avis, wmv's or mpeg's again, where you can set the max output size.
Thanks for reading![]()
What?!?!mpeg's i take off my sony digital camera into a compressed video format
You're not gonna get more compressed than an Mpeg..
That's backwards...than can convert mpegs to avis
Are you talking about movie clips, or pictures?? Do you wanna email this stuff, web stream it, or put it on DVD??
This is dictated by the bitrate that you set up before encoding....where you can set the max output size
What's your source, what's your destination, and for God's sake, what's your hardware??
Now, with that bit of information Luke Skywaker, read up on the Left hand side, and you too, will become a JEDI Night... -
well they are really high resolution, i used to turn them into wmv's and they were fine.Originally Posted by pijetro
movie clips, i just want to put them on the web for friends to download. so taking a clip thats 50mb to like 15 is the goal, retaining original quality doesnt really matter... just making them smaller and knowing how small they are going to be before hand.
indeed... im just looking to make it easier on myself, just click the size i want and let it encode instead of a bunch of trial and error.
i have a toshiba a10 satellite. 2GHz, 512RAM, 40Gb hard drive
thanks for everyting
You should fill out the computer details in your user profile.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Alrighty, quick one...
You know how to output for .WMV from your previous posting...
Since you've already done this before, here's a few tips to get your filesize down..
Video framesize should be 320x240
Video Bitrate should be around 500kbs (prefferably with Variable bitrate)
Audio should be about 22khz, 8 bit, mono.
Framerate should be 15fps (very important)
And as to your original posting..Windows Media Encoder should be good enough.. -
i use window movie maker now, and its just so irritating for freezing. i read the reviews for WME and it seemed like its pretty much the same thingOriginally Posted by pijetro
ill give it a shot though 8)
Recommend video conversion program for older hardware?
By mr-scarface in forum Video ConversionReplies: 1Last Post: 4th Mar 2011, 03:29 -
Program for video conversion VC-1 to H.264
By wisitch in forum Video ConversionReplies: 1Last Post: 5th Apr 2010, 16:00 -
just a basic all around video editing program
By malakov08 in forum MacReplies: 6Last Post: 30th May 2009, 00:34 -
A basic, simple video editing program?
By Salva Veritate in forum Newbie / General discussionsReplies: 5Last Post: 25th Jul 2007, 15:50 -
Program for basic DVD authoring
By netimen in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2007, 20:25
